enginegeek21
Is there a way to increase the hydraulic pressure on a tractor??? Our Farmall 560 diesel is way lower than what we've expected it to be (Around 1300psi) and I think I've found the part to fix the problem... Our Regulator and safety valve had worn out O-rings and gaskets, so we put new ones on and it still didn't work. So then we bought a refurbished one and it still didn't work... Is there something inside the Regulator and Safety Valve??? If not are the 3 control valves under the steering wheel my other option to fix???
Thanks,
Bryce C.
Thanks,
Bryce C.
