Inner tube recommendation
chas036
I have to put two new rims on my JD 730 because the originals all rusted out from calcium leaks over the years. I am not going to be reloading the tires and I will have to get two new tubes. I know there is a lot cheap China and Korea tubes out there on the market, but I want something that is good quality and will last. Can someone recommend a place where I can buy a good quality made tube for 15.5x38 tires.
Chase, after owning a tire dealership for 22+ years and installing hundreds of farm tires, best advice go to a local farm tire dealership that sells a lot of tires and buy Heavy Duty Radial tubes. Radial tubes will work great in bias or radial tires. If you buy them from somewhere that doesn't move a lot of tubes, you can get tubes that have been on a shelf for a year or two. If you get one of these, there is a good chance it will have cracks in it where it is folded. Same way buying them online. Good luck.
Firestone makes about 3-4 grades of inner tubes. Imported, Imported from a Firestone plant, Better or Radial Imported, and US made radial rated tube.
5-6 years ago I had a flat tire on my only tractor with fluid. I pulled the rims/tires off, had local tire shop demount the tires, they were rusted on tight! Sand-blasted primed and painted the rims and put new Firestone radial tube in them. One said Firestone, made in Korea, other said Made in USA but nowhere said Firestone. I have had no problems with either tire. Shop I bought the tubes at was the biggest Firestone dealer in the state.
