So i narrowed down the part i needed on my NH 8260 cab tractor, picked it up at the dealer and thought it would fix the problem but no such luck. One day i got on it, started it up and was given an error code (E65...high solenoid open circuit) on the dash, the tractor would not move at all, after starting it up several times i was on my way, does good on the low side of each gear but if you hit the rabbit button on the shifter the tractor stops and E65 flashs with the alarm. The part i bought was 82008511, which is a solenoid valve w/spool for the hi and low. Dealer seemed to think this was the problem, but i still do not have high range. i don't know what to try next, could it be a bad ground or a wire chewed into by a mouse?? It was working good one day and did this a couple days later. Any help would be appreciated.
