JD 3020 gas looses electrics when hot
Andy McMurry
New User
Looses all electric functions and dies when it's working warm. Comes back when it cools off. Is there an over heat circuit relay cut off?
jD dealer sold me a starter relay, does that sound right?
Many thanks for help suggestions!
" Is there an over heat circuit relay cut off?"
No.
"jD dealer sold me a starter relay, does that sound right?"
No.
Gas or diesel? Serial#?
Does the engine shut down when this happens?
(quoted from post at 14:51:58 06/16/18) " Is there an over heat circuit relay cut off?"
No.
No.
Bob, thanks for your willingness to help. It's a gas tractor. It does die, when electrics shut off. I will get the serial # soon.
No.
No.
Serial # 211958T. Type 4219GR03
Classic symptom of weak, or failing coil or condenser.Rplace condenser first./There is no Reliable bench test
(quoted from post at 15:24:10 06/18/18)
(quoted from post at 12:52:46 06/18/18) Classic symptom of weak, or failing coil or condenser.Rplace condenser first./There is no Reliable bench test
Thanks very much, I will do just that!
Andy, wondering if you've got this fixed?
You stated "Looses all electric functions and dies when it's working warm.".
If that's TRUE, it's not a condenser issue, that could cause a stall, but would have no effect on "losing all electrical functions".
(quoted from post at 07:31:30 06/20/18)
Thanks for checking in. Good thoughts. I'm waiting on a new circuit breaker. Will start by replacing it. Also I noticed when the issue happens I do get dash lights but only when the key is turned all the way counterclockwise. ( opposite direction of when cranking the starter). I figured this might be a good clue to the right person.
