I just started the JD 4450 that I use on the one round baler. It is already 86 degrees here and humid. Pulled it over to the fuel tank. While I was fueling it I thought I heard some thing POP. Shut everything off and sure enough one of the cab lines was whistling under the cab post cover. I took the cover off and there is a hole in the side of the rubber line. The entire AC system was replaced just two years ago.
So I now have to go out and switch the baler/monitor over to another tractor. There is no way I could take running the baler in a cab tractor today without the AC working.
