Gene Dotson
Fred, Friend has need for VAIW Case 3rd and 4th speed sliding transmission gear. Case part number is VT4126 Ad has 38 teeth on big side and 23 teeth on small end. Only used on VAIW series tractor. VA and VAI are different.
This gear has 1 broken tooth on the big side and could be repaired by a skilled machinist if a good part can not be located. I know there are skilled repairman on this board and would welcome all responses.
