ChasK
The weld holding the clamp ring to the rim has broken for about an 18 inch stretch. That weld is real close to the bead of the tire. Can i weld this with the tire on after letting the air out of the tube?
My thinking is the tube would slide to the other side of the tire, and I can make short passes to keep the heat down to prevent damaging the bead. Will that work or am I looking at taking the tire off the rim?
