Vacuum trick results
Well my hydraulic hose came in today and I tried the vacuum trick to change it on my Massey. Absolutely not one drop of oil came out. But I had buckets at the ready in case it didn't work. Popped the old hose off, put the new one on, topped off the oil (lost some while sitting waiting for the part) and we were good to go in 10 minutes.
The hose is the bottom sump hose for the hydro, which contains 11 gallons of oil. Hose had a small crack in it, and was leaving drips on the floor. When I ordered the replacement hose I asked the dealer if he had any advice. He said don't drain the oil, hook a vacuum cleaner hose to the fill tube and turn it on. Then remove the hose, and no oil will leak out because the vacuum is holding the oil from running out. And, the air volume in the top of the housing keeps the oil from being sucked into the vacuum. I posted here for advice as it sounded like a mess in the making, but most replies indicated the process does work. And sure enough it did.
About 40 years ago I tried a system similar to that (crankcase evacuation) on a race car. Built a venturi into the exhaust system which was hooked to the crankcase vent. Did prevent leaks but also sucked in the valve cover gaskets.
