Tractor Talk Discussion Forum
Re: Won’t crank
Steve@Advance
04-23-2018 12:50:24
Did you bleed the air from the injector lines? As in crack the fitting loose at the injectors until solid fuel comes out.
If there is no white exhaust smoke (fuel vapor) it is not getting fuel.
You probably won't get oil to the rockers just cranking. Once it starts be sure it gets oil pressure, let it run a while, they should start oiling.
