Re: Head replaced - it won?t crank
jonsmith
Yes It turns over fine. The oil pump does not appear to be working or
is gummed up from old oil with water in it? Will this keep it from
cranking? What else could it be? Injector stopped up? Bad fuel?
(quoted from post at 13:26:06 04/23/18) Or starting? It will turn over fine. Valves not adjusted right? Will this
cause it to not start?
Yes incorrectly adjusted valve clearances will cause engine not to start running. Also air in fuel system will cause same thing.
