SodBuster87
So got the 3pt hooked up hyd plummed but now the hyd valve screeches when the lever is in center( neutral) postion. Is worse when I first start the tractor but after I run the 3pt lift cylinders through a couple of complete retract-extend cycles it goes away until the next time I start the tractor. I should also note that after a couple of cycles the speed of both raising and lowering greatly increases. I have not ran the tractor more than 10 minutes since adding 3 pt. Sticky valve? Air in system? Hyd lift cylinders are one way. This is on a Farmall 350.
Thoughts?
Thanks, Sod Buster
Thoughts?
Thanks, Sod Buster
