Olliejunkie
Eldon sent me these pics. I posted them on his post but didn't get a response so thought I would try a new one.
Somewhat similar to a JI Case single bottom rollover plow. It doesn't roll over but one bottom at a time in each direction. Parts missing
though. Nick at Ky has one like I am thinking about...maybe he'll stop by and give his opinion.
Seems like MH made plows for their little tractors that worked like that so you always stayed in the same furrow. Pony or Pacer maybe.
In the second pic at the upper right of the mounting point it has two irons around 4" apart. The LH side has about a 1" dia. hole. and the LH side has a slot of the same diameter and an eye bolt to lock the shaft or pin in place.
That is a Case VCMTA Two- Way plow for a Pre-Eagle Hitch VAC. There is a lot of complicated mounting and lifting hardware missing.
A lot of good parts there though.
Below is a link to an ebay ad for this plows parts book.
Nick
Untitled URL Link
(quoted from post at 20:06:37 04/22/18) That is a Case VCMTA Two- Way plow for a Pre-Eagle Hitch VAC. There is a lot of complicated mounting and lifting hardware missing.
Nick
Untitled URL Link
Thanks Nick, that is it! The dark green paint I saw on it threw me...no orange paint on it that I could see.
(quoted from post at 20:15:23 04/22/18)
Nick
Untitled URL Link
Yes...thank you all. Hopefully someone can use it.
