MH 44 Wheel locked
Goldinger
New User
We put our 44 in the shop for tires and paint. When we did, both rear wheels spun freely, but now one is locked. No idea why. We have had this tractor since it was new and have never had any rear end trouble. Thank you for any help.
Jim
Most likely to be a stuck brake but can also be a bad axle bearing but I would start with the brake and than go from there
If it is stuck tight with no movement at all, most likely stuck brake.
Can't think of anything in the rear gearing that would lock one wheel.
Does it have disk or drum brakes?
I had the rollers ramps crap up in my disk brakes, took them apart and cleaned.
I got some time to look at the 44 project. It was the brakes, just like you folks said! My thanks to each of you!
