TractorLinks.com
PTO Welder/Generator for 3-point
Tom
11-13-1998 08:16:11
Am in the market to purchase early next year, a welder/generator; probably about like the Miller BobCat, ( arc welder/ 8000 watt generator ) which has an 18 HP engine. Seems like a waste, since I have a NH 1630 compact diesel tractor. Would like to avoid gasoline storage, separate engine maintenance, etc. Does anyone know of a PTO, 3-pt hitch, welder/generator??
Thanks
DY
11-14-1998 10:44:44
 Re: PTO Welder/Generator for 3-point in reply to Tom, 11-13-1998 08:16:11
: Am in the market to purchase early next year, a welder/generator; probably about like the Miller BobCat, ( arc welder/ 8000 watt generator ) which has an 18 HP engine. Seems like a waste, since I have a NH 1630 compact diesel tractor. Would like to avoid gasoline storage, separate engine maintenance, etc. Does anyone know of a PTO, 3-pt hitch, welder/generator??
: Thanks
Do you happen to have a regular plug in welder?
I have a PTO generator and use my 220 welder with it.
Blazina
01-27-2000 00:16:45
 Re: Re: PTO Welder/Generator for 3-point in reply to DY, 11-14-1998 10:44:44
Look at the ZENA welders -- they have pto drive models, hydraulic drive models, &
models which install/attach directly to tractor
engine.
www.zena.net/htdocs/Map.shtml
Tom
11-14-1998 17:02:41
: : Am in the market to purchase early next year, a welder/generator; probably about like the Miller BobCat, ( arc welder/ 8000 watt generator ) which has an 18 HP engine. Seems like a waste, since I have a NH 1630 compact diesel tractor. Would like to avoid gasoline storage, separate engine maintenance, etc. Does anyone know of a PTO, 3-pt hitch, welder/generator??
: : Thanks
: Do you happen to have a regular plug in welder?
: I have a PTO generator and use my 220 welder with it.
: Thanks, I haven't bought yet. What brand and output of generator do you have? How much does one cost? Do you plug in something like a Lincoln 225 240V AC welder? I am interested in going this route if the generator is readily available and not too expensive. Thanks.
DY
11-14-1998 20:44:58
 Re: Re: Re: PTO Welder/Generator for 3-point in reply to Tom, 11-14-1998 17:02:41
: : : Am in the market to purchase early next year, a welder/generator; probably about like the Miller BobCat, ( arc welder/ 8000 watt generator ) which has an 18 HP engine. Seems like a waste, since I have a NH 1630 compact diesel tractor. Would like to avoid gasoline storage, separate engine maintenance, etc. Does anyone know of a PTO, 3-pt hitch, welder/generator??
: : : Thanks
: : Do you happen to have a regular plug in welder?
: : I have a PTO generator and use my 220 welder with it.
Yes, that's the kind of welder that will work.
Does your tractor have a 540 RPM PTO?
Our power company sells them about at cost.
A kilowatt of generator needs about a horsepower.
I think mine is a 25 kilowatt.
New they sell for about $1,500, used on sales about half that.
It really does the standby generator good to use
ocassionally to make sure it works.
It always seems like a guy is trying to get it going in the dark and cold.
Tom
11-15-1998 07:23:36
 Re: Re: Re: Re: PTO Welder/Generator for 3-point in reply to DY, 11-14-1998 20:44:58
: : : : Am in the market to purchase early next year, a welder/generator; probably about like the Miller BobCat, ( arc welder/ 8000 watt generator ) which has an 18 HP engine. Seems like a waste, since I have a NH 1630 compact diesel tractor. Would like to avoid gasoline storage, separate engine maintenance, etc. Does anyone know of a PTO, 3-pt hitch, welder/generator??
: : : : Thanks
: : : Do you happen to have a regular plug in welder?
: : : I have a PTO generator and use my 220 welder with it.
: : Thanks, I haven't bought yet. What brand and output of generator do you have? How much does one cost? Do you plug in something like a Lincoln 225 240V AC welder? I am interested in going this route if the generator is readily available and not too expensive. Thanks.
: Yes, that's the kind of welder that will work.
: Does your tractor have a 540 RPM PTO?
: Our power company sells them about at cost.
: A kilowatt of generator needs about a horsepower.
: I think mine is a 25 kilowatt.
: New they sell for about $1,500, used on sales about half that.
: It really does the standby generator good to use
: ocassionally to make sure it works.
: It always seems like a guy is trying to get it going in the dark and cold.
Thanks,
I will check with our local electric co-op to see if they have literature. My tractor has a standard 3-point and a 540 PTO. If you knew the brand name/model, I might be able to find their internet home page.
Namin Clark
01-19-2000 17:30:36
 Re: Re: Re: Re: Re: PTO Welder/Generator for 3-point in reply to Tom, 11-15-1998 07:23:36
: Hello sir,
I would like a number to call you, so i can ask some questions. One is the cost, and the cost to ship the generator. please rspond quick.
thank you
: : : : : Am in the market to purchase early next year, a welder/generator; probably about like the Miller BobCat, ( arc welder/ 8000 watt generator ) which has an 18 HP engine. Seems like a waste, since I have a NH 1630 compact diesel tractor. Would like to avoid gasoline storage, separate engine maintenance, etc. Does anyone know of a PTO, 3-pt hitch, welder/generator??
: : : : : : Thanks
: : : : Do you happen to have a regular plug in welder?
: : : : : I have a PTO generator and use my 220 welder with it.
: : : Thanks, I haven't bought yet. What brand and output of generator do you have? How much does one cost? Do you plug in something like a Lincoln 225 240V AC welder? I am interested in going this route if the generator is readily available and not too expensive. Thanks.
: : : Yes, that's the kind of welder that will work.
: : Does your tractor have a 540 RPM PTO?
: : Our power company sells them about at cost.
: : A kilowatt of generator needs about a horsepower.
: : I think mine is a 25 kilowatt.
: : New they sell for about $1,500, used on sales about half that.
: : It really does the standby generator good to use
: : ocassionally to make sure it works.
: : It always seems like a guy is trying to get it going in the dark and cold.
: Thanks,
: I will check with our local electric co-op to see if they have literature. My tractor has a standard 3-point and a 540 PTO. If you knew the brand name/model, I might be able to find their internet home page.
Jim Fisher
11-15-1998 14:31:22
: : : : : : Thanks
: Thanks,
Here is a link to Winco's home page. These show up at farm auctions on occasion and usually sell for a lot less than new price.
