How do you turn the crank to adjust the valves using the "TDC"
mark. I tried engaging the PTO and using a pipe wrench to turn the PTO shaft. I took the tractor out of Gear, but when I turn the PTO the tractor tries to move like it is engaged??
I'm following the manual, but it doesn't give me any direction as to how I turn the motor to line up the TDC mark on the flywheel to set the valve tappets? I'm not a mechanic, but can follow instructions.
