Coating Tank
Exactly the same as any other coating on any other type of material. Very poor to very good depending on the preparation.
Red Kote would work fine for diesel. The difference using it in a diesel tank is the inside of the tank would have to be thoroughly cleaned with acetone or other strong solvent before using it.
I have POR 15 tank liner that has been in my tractor's tank for about 7 years, no problem. Just bought some Red Kote to do a motorcycle tank. Doing some research it has mixed reviews. Check the web there are more than a few Youtube videos on the subject. POR 15 applies a relatively thick liner where Red Kote is a thin flexible film and is used for pin holes. Larger holes need to be repaired. As was stated, it appears that good preparation is paramount.
I use POR. They have a kit that includes a cleaner, etching liquid and the sealer. If you follow the directions, you will have no problems. I have 5 tractors that I have used the POR in with no problems. First one was about ten years ago.
