AC 210 injection pump
redboots
New User
Just purchased a 210 and it is leaking fuel at the injection pump fuel shut off arm. Should I have it fixed by a professional shop or is it possible to fix myself? Not really a great mechanic with a lot of tools. It leaks a lot when running. Thanks!!!!!
That tractor has some value. I wouldn't pinch pennies trying to seal up a leak. If the throttle /shut off shafts Are leaking, they are trying to tell you the age of the rest of the seals in this pump. When the drive seals start to fail they let diesel into the engine oil. It costs WAY more to repair an engine than reseal a Roosa pump. I did the same pump a couple weeks ago for $460.00 with one year warranty. You cant put a wrench on that 426 engine for that money. Al
