Scottish tractor pic
jamstra
Finished and outside! Now for part 2 - a re-furb of the NH 445E mower on the back!
wow looking great jamstra, you have a few hours in that refurb, I hope I can get my mm m5 looking 1/2 that good when i'm done my refurb this spring.
Hi Loren,
They are standard MF40 loader mounts - one belly bracket you can see in the pic (carries the rams), second one bolted to subframe between front wheels. Neat set up and works just fine - has loaded thousands of tons of muck, stacked thousands of bales, ploughed a lot of snow over the years - never bent or broke anything. Hydraulic power from internal pump, plenty of flow and pressure for main and tilt rams together. Thanks for your comments, Jim
Ehrm...thanks, I think! Jim
PS tractor will still be in use, but only for some pasture topping and moving bales of haylage.
