In the time waiting for the carb, something has happened. There is no spark.
I knew it was old, so I bought a new battery. Now the H turns over very fast but it doesn't fire.
The test light shows power down to the connection on the coil. I ended up buying a new coil now since I figured it was the problem as it was all oily and I read that they will leak when they go.
The guy I bought the tractor from who ran a small shop installed electronic ignition several years ago so there are no points to gap or condensers to fail, etc.
The coil wire does not give off a spark when next to the frame UNTIL I let off the starter button and I get one small yellow spark.
I have new spark plugs, plug wires, distributor cap and rotor already on, but I can't get much out of the coil wire.
What am I missing and what would cause this spark issue? I don't get it.
