Jd2510 seals on load shafts
Drop the oil out, remove the lower links, slide the draw bar out, remove the 2 side caps, push the load shaft out, let the "A" frame swing down,,be ready for the swing down part,,it can put a dent in your head..
Tim, you forgot to tell him in what position to put the load control lever before pulling the pin to avoid having the internal fork move out of place, making going back together difficult!
And, I can never remember for sure, myself!
Put the load shaft selector in the d
position. Get washers to shim it side
to side. I use an old load shaft as a
tool to drive the old seals and or
bushings out.
