So I am trying to get this old 1 ton back up and in good working order. It will run but I have to have the coke pulled most of the way out or it dies. With it this way it seems to not want to take gas when you try to throttle up. If you sort of feather the throttle it will rev up but not well. I am thinking that maybe it is the vacuum brake booster and if it is bad it might cause a intake vacuum problem. Brakes have not worked on it in decades. I'm think about unhooking the host at the manifold and capping it off to see if that helps. By the way I did rebuild the carb about a year ago and it has run this same way since doing that plus before I did the carb rebuild.
Any body have any ideas on this. Ford 1 ton 300 straight 6 with a one barrel carb
Thanks
Thanks
