KCTractors
- Location
- Central Wi
This is probably a stupid question, but here it goes! Can I use a length of steel-core spark-plug wire to use for a coil wire?
I have a Ford 8N side distributor and I am not getting any spark through the cap to the plugs. I have replaced everything with NAPA parts. I cleaned the distributor, weights and plate nice and shiny. New points, condenser, rotor and cap and the clip holding the rotor down. I have a good spark at the points when I open and close them. New coil from Napa also. The only thing I don't have is a new coil wire. My ohm meter says the coil wire isn't broken.
