A couple projects
SVcummins
It was a nice day so I though id start on the welder project fixed the broke off exhaust stack got the shields off and blew out all the dust I could . while i had the compressor going I thought I may as well see if I could get the bolts loose on the 3020 wheel hubs I've been soaking them since I bought the tractor with a jb 80 probably sprayed 6 cans on the wedges and what I could get to off the bolts. My half inch iimpact broke the bolts loose easily the bolts were wet when I when i pulled them out i tightened the Jack bolts down and smacked the three big bolts on each wedge with a sledge hammer and the wedges popped loose on both wheels
I've fought these wedges before spent a week beating on a dual hub on my 4020 finally got it apart and then took it to a shop with a hyadraulic press to press the bolts out of the hub it took 80 ton to get them out guy at the shop said he was about to run out of press when they finally gave. At the Ford dealership me and two other guys spent a week getting trying to get a wedge loose on a big Ford
