1000 PTO to 540 PTO
I have round large round baled with a 540 RPM baler and 1000 RPM tractor and it is not fun. You have to run the tractor as such low RPM that you don't have adequate tractor power when you need it; i.e., pulling up hill, turning, etc. I was constantly shifting. However, if you were baling on level ground it would probably not present as much of a problem.
It depends on the tractor, my brothers 7710 Ford has a 1000 pro rpm shaft with it. You just swap the shafts out, the 540 runs off one gear while the 1000 runs off a different gear so you can use the 1000 at normal engine speed.
