Hey Everyone,
I am in the process of rebuilding a John Deere 530. Several of you answered some questions for me over the last few months that I really appreciate. I am not remounting the tires/wheels and have 2 questions on mounting the rim or center weight to the actual tire or tire rim. I know I need to tighten the 8 bolts uniformly meaning I should tighten in a crosswise pattern to be sure they are pulled uniformly. I did that but it still seems like the center rim or weight is 1/8" off in places so not sure if that is uniform enough or not. I am just measuring the distance from the center rim is from the grove on the tire rim.
also, how tight should I get these 8 bolts? is 150lbs torque enough?
thank you
thank you
