TractorLinks.com
Tractor Talk Discussion Forum
Draft Controll picture
pat sublett
02-13-2018 17:51:11
Confused about draft control on MF 135. The outside lever which is the tallest and has a round knob, doesn't do anything. The only way that I can raise the plow is to push the inside lever with a square knob and shorter lever down. Doesn't make sense to me. Tractor has been glamorized. Looks to me the decalls may not be right.
Two Dogs
02-14-2018 17:31:12
 Re: Draft Controll picture in reply to pat sublett, 02-13-2018 17:51:11
Evidently My tractor and the one I was raised on work bass ackwards from every one else's or either I don't understand. I put the draft (the short square knob outside lever) all the way down and use the inner one with the round knob to raise and lower the lift. TDF
FinnMD
02-14-2018 16:42:20
Actually to properly use the 3 point the outer Draft needs to be pulled all the way back and leave it there, not set in middle. You then just use inner control to raise and lower 3 pt. Draft was made for ground engaging implements. Inner control lever for raising lowering 3 pt.
TimWafer
02-14-2018 13:36:05
If you notice the writing is facing the wrong direction (away from operator) on the red decal. It should just be turned end for end. Set the draft control in the middle somwhere and forget it. Its only useful while plowing or some such ground engaging function.
Jo Bird
02-14-2018 07:09:31
Quoting Removed, click Modern View to see X2 what Tim says.. inside decal is " Upside-Down "
TimWafer
02-14-2018 04:24:22
I would say the red decal is on backwards. Reverse it and I think it will make sense to you. Red lever raises & lowers, yellow is draft control.
Dieseltech
02-13-2018 18:11:38
The inner position lever should be in the UP position and left there. Then the outer draft lever can be used for ground engaging implements. The position lever is used for hitching, or anytime you want the three point to hold a given position. Draft lever must be left fully up during position lever use. There's a chance the decals are wrong too. Some tractors had the Pressure control option, top part of the position quadrant was for position control, lower part was for pressure control hitch use. Draft decal is correct on both though.
pat sublett
02-13-2018 18:19:35
 Re: Draft Controll picture in reply to Dieseltech, 02-13-2018 18:11:38
It want raise until you push the inside (red) lever all the way down. Location of the outside doesn't matter.
Dieseltech
02-13-2018 18:29:41
 Re: Draft Controll picture in reply to pat sublett, 02-13-2018 18:19:35
My 135 diesel inner position quadrant decal is opposite of yours, fully up/back is constant pumping, slightly forward against the constant pumping stop is UP, forward travel is position control down. With the position lever in the up location, the outer draft lever should lower the arms. If not, some thing is wrong inside.
