alexis.marcil
Is it normal for a starter to grind occasionally (half the time I start it) for 1 or 2 second then it stops and run smoothly until the motor start? I removed the starter, cleaned it, the teeth looks nice. The flywheel teeth also looks normal, not grinded or worn. I did a bench test and everything works fine. I don't think it's a bendix type because when I disconnect the power, on the bench, the gear returns to place without centrifugal force. I supposed sometime the teeth are not aligned between the starter and the flywheel and it grind for a few teeth before taking it's place... should I be worried?
thanks
thanks
