1980 payloader need some advice on engine
djg12345
New User
it?s non turbo and it?s not original motor .... it?s been running great have used it off and on for the 6 months I owned it no more than a hour or 2 at a time ....last night I pushed snow with it for 6hrs or so then it started missing and blowing a little blue / white smoke ....I found he air filter had a lot of snow in it so I blew it out and it ran great again for about 30 mins then started missing and smoking again but this time wasn?t the filter.... after I got it back to my shop I notice oil around where exhaust manifold meets engine block .... any idea the problem ?
I would say that your engine is suffering from internal damage on that one hole that is pumping oil white blue smoke is a sign of incomplete fuel burn due to low compression or at best a bad injector . Now as to the low compression it could be caused by a burnt valve , scored cylinder wall , burnt piston ,could be a blowen head gskt. Diesel engines really don't like water getting in them or being choked off from getting air.
