new loader mounts?
Looking at a loader for sale on Craigs list. Just wondering how hard it would be to find mounts for a Farmall 350. Says it came off a John Deere two cylinder. Also it looks like the vertical support brace is removed https://stcloud.craigslist.org/grd/d/hydraulic-loader/6454139267.html
The "vertical support" braces are there. they are the pipes you seehanging diagonally.The bolt to the front of the frame rails. That loader is kind of a 'universal' loader. It will fit about any tractor with minimal mods.
(quoted from post at 19:28:05 01/20/18) The "vertical support" braces are there. they are the pipes you seehanging diagonally.The bolt to the front of the frame rails. That loader is kind of a 'universal' loader. It will fit about any tractor with minimal mods.
I see them now. I must be going blind.......
I've got one of those here that came off an 806. The axle brackets are on it but they look home made.
Okay looking at the picture again. Would u bolts of the appropriate size and grade hold up or would they bend/break or otherwise fail. Also wondering about the width the mounting pads are apart.
U bolts would be sufficient. But for simplicity,2,or 4 long bolts per side and a steel plate behind the axle wold be fine.I think the one I had had that set up. In fact I think it just had 2 bolts per side.I think the width would be fine,the same as yourtractor.whenI bought my loader I mounted it or a 730JD. Later put it on an M. Don't recall having to do any modifying. Was just a bolt on deal. But that was over 30 years ago......
Mine uses six 5/8 bolts per side to bolt the mounts
to the frame and then two 3/4 inch bolts on each
side for the loader to the mounts . If your tractor is
short enough you won?t need the mounts like have .
that looks a lot like my Dual 325 loader I purchased used about a year ago. The length of the mounts depends upon tractor. I don't know what mine came off of but bolted up to my SMTA with no problems. Those mounts that go to the axle apparently take a lot of stress as mine had some cracks so I rebuilt them. I was able to get an operator's manual for the loader, but that did not give dimensions of the mounting brackets for different tractors. The ones from the JD might work or at least give you a place to start.
