2006 f150 4x4 hauling
Depends on what your trailer weighs plus what the G weighs. My 12K lbs. gross trailer weighs 3800 lbs. empty. A G can weigh 5500-7500 lbs. So you are talking about towing maybe 9300 bs. to over 11,000 lbs.? A V8 F150 is rated to tow a max of 9300 lbs. and a V6 around 7000 lbs.
Not in the doorjamb, but in the owner's manual.
"Heavy duty" is meaningless. People put the "heavy duty" label on everything. You see "heavy duty" trailers advertised all the time and they turn out to be cheap-o 4x8 folding Harbor Freight specials. NOT heavy duty!
A JD G can weigh anywhere from 6000 to 7500bs. A trailer built to handle that much weight will weigh 3000-3500lbs. All in all you are looking at around 9,000-11,000lbs of load.
Many F-150's are rated to tow 11,500 but that's maximum capacity, and is utilizing every drop of the truck's payload capacity to handle a 10% tongue weight. If you have passengers, tools, a bed topper, or any other aftermarket addons, that will detract from the payload capacity and put you in overloaded territory. For sure you will need weight distribution to keep from overloading the factory receiver, as it is only rated for 500lbs, and only 1000lbs with a weight distribution hitch. Then you need to achieve perfect balance on the trailer so as to not exceed the 1000lbs.
That's the "by the book" analysis. Nothing stopping you from hitching up and going. Many do. Most get where they need to go without any issues. Most of the rest have minor issues such as a white-knuckle moment or a flat tire. BUT, there's always the one that totally underestimates the situation and runs out of brakes, road, and ideas all at the same time.
If you do try it make sure the trailer has GOOD brakes. You will need them.
It also depends on the trip.
Flat land or mountains?
Is this a one time haul, local, long distance?
The ratings are generally for warranty purposes, as in using the truck at that capacity on a regular basis.
If this is a one time, local haul, and the trailer is properly balanced, has good brakes, and the hitch is rated for the load, you can push the rating a little, just be careful.
Here's the link.
https://www.fleet.ford.com/towing-guides/
Download for 2006. The biggest number in the chart is 9500# for a 4x4, with a lot of 'it depends' on engine, rear end. I would say you will be at, or just over the max weight depending on your trailer. Supercab, 4x4 with 5.4L, and 3.73 gears will tow 9300#. Weigh your trailer.
Check your manual, and look carefully, ratings can depend on things like load leveling hitches.
Trailer brakes are a must.
Comment to Barnyard, 2006 ford is different between standard duty and heavy duty, load capacity is different, one item to check for on which is which is wheel bolts, standard duty is 6 bolt, heavy duty is seven bolts, this is an easy visual check. I'm sure there are other items.
Actually it is in the door jam - it will list the specific GVWR of your vehicle as it came from the manufacturer. The manual shows the various ratings depending on your set up - if you don't know your specific set up the manual isn't telling you much besides the range that can be towed.
https://www.ford-trucks.com/forums/attachment.php?attachmentid=5530&stc=1&d=1185887433
In 2006 the maximum tow rating for any F150 was 9900 pounds (long bed regular cab 4X2 with 5.4 and 4.10 gearing), the higher ratings came later.
https://www.fleet.ford.com/resources/ford/general/pdf/towingguides/2006RVguideApr08.pdf
The one question not asked is how often are you going to haul this tractor? If your only hauling it several times you will be OK but if your going to haul it a lot get yourself a bigger truck. I pulled a 4,200 lb. deckover with a K1500 4X4 hauling one of two tractors(6,000 & 8,000lbs.) and am going through a transmission and rear rebuild right now.
Also don't forget the tire ratings....the standard 6 ply tires aren't going to cut it they will be
overloaded especially on the rear. Think 10 ply
Let just tell you want I have learned in my trailer towing life. I had a 1995 F-150 with a 351 Windsor fuel injected engine. Super cab. If I had hooked it up to my car trailer and had a John Deere G 1951 tractor on it with wide front. So lets do the weight on math on this. The car trailer is 2,000 pounds alone the John Deere G 1951 wide front with back weights on it is weighting about 6600 pounds. that is a total of 8600 pounds. Where did I tow it to around town level land no hills to climb or go down hills. the truck did okay towed alright. Now if I was going to tow up high grades and go down High grades plus do distance I would have used MY 2006 F-250 Super duty 4X4 diesel truck. I learned many years ago maybe a 1/2 ton could but be ready to spend money on truck repairs when done towing. All I have to say do the math on the weight you plan to tow. then use better judgement on it as you tow the weight.
I almost jackknifed my 1999 F150 with trailer and 6610 with loader on it going down hill, had to actuate the trailer brakes and straighten out.
For occasional use over short distances in flat country, you would probably get away with it, but it would be marginal at best with no room for error. A 3/4 ton pickup is what is needed for that type of load. A 1/2 ton pickup will have the engine to pull it, but not the brakes to stop it or the springs to keep it under control in an emergency.
Road gear on that tractor would be around 12 MPH, enjoy the ride!
I use my F-150 4X4 to pull a 25ft goose neck for light duty and get along fine,, I took it to Rantual last summer with a load of toys,,it don't get used every day doing this but handles 8,000lbs or so well,,as far a jack knifing an outfit,,you can do that if your not careful with bigger trucks and bad brake systems..Yes I added an extra leaf spring to it and it came with a towing kit option,,I added the hitch also..it has the 5.4 V8..
Little know tidbit. I have a Ram 1500 crew cab Mega-Cab 4x4. The whole thing is on 3/4 ton running gear, but it's called a '1/2' ton truck. The hubs, brakes, axles, gears, shocks are all the same. The only diff is one leaf on the back, and the tires. However, I added the spring and truck tires, so I have a 3/4 ton for 1/2 money. The 'book' says my towing capacity is 2300Lbs less than the 3/4 but it's all the same metal. I matched the replacement brakes, bearings, hubs with the 3/4 ton so I know it's the same.
