Farmall m service/shop manual
Wilkernut 88
New User
Looking for a good service/manual shop manual I see a few
on Steiners and amazon. I need something that gives all
torque specs. Does anyone recommend one from somewhere
else?
This will be the second time I?m checking for a cracked head
or block or did I just not torque the head studs correctly at 110
pounds
I bought mine from this site.
Service manual, Maintenance manual and Lift-All manual
recopy but they are all good.
I got the one from this site, link below. Blue Ribbon service manual. doesn't cover everything so I also have an IT manual which is more general.
...nut88 welcome to YT. Did you use a sealer on the head gasket? I recommend Copper Coat. Did you get engine up to operating temp and re-torque? Both of these need completed to assure a good seal on these thicker sandwich type head gaskets. What issue are you having?
I did use high temp rtv. I did not re-torque head studs nor did I change them. I have antifreezes in the oil and oil in the antifreeze. I have the oil pan off and can see antifreeze running down from the fourth from rear push rod. I cleaned everything up to see better once all were dry I noticed the next day all rods near the cam were wet again. And I did not have the head checked for cracks either so I?ll be doing that this time
