Tractor Talk Discussion Forum
Re: Kubota’s seem to start well in the cold
Mathias NY
01-14-2018 15:24:17
Thanks for the insight on the M6060, I'm looking to purchase one before spring. What rear tire size are you running and are they loaded with fluid?
I'm planning on purchasing it with the 30" cast rear centers and having the tires loaded. That should give around 3000 lbs of weight on the rear wheels. On paper that should be enough to keep them on the ground with a full load in the bucket, but I am planning to keep them set pretty narrow and now I'm concerned that it won't be enough.
jm.
01-14-2018 17:55:40
 Re: Kubota’s seem to start well in the cold in reply to Mathias NY, 01-14-2018 15:24:17
If you get the cast center and add fluid it will pretty much handle anything the loader picks up .Lots of folks will not pay for the cast centers.
Keith Molden
01-15-2018 05:49:47
 Re: Kubota’s seem to start well in the cold in reply to jm., 01-14-2018 17:55:40
The dealer didn't say anything about cast centers. Maybe miner will be OK with setting the wheels out and adding a couple rear wheel weights off a Massey Harris that I have laying around here. Keith
