[email protected]
New User
I completed installation of a new 12 volt battery, hooked the 2 12volts in series (right battery negative to left battery positive) and established a positive ground off the left battery. Vola, the lights worked..until I started the tractor. I did some reading and polarized the generator by momentarily connecting the batt to arm/gen contacts on the regulator. No dice. Volt meter show -24volts at the regulator and starter. Is this reverse polarity normal? The gen light also has come on, with the key off, when the positive ground is attached. It goes out when I disconnect the positive ground, so I think there must be a short in the system?
Any advice, other than 12volt conversion?
Thanks again!
Thanks again!
