big tee
I am building a vertical tillage tool and am putting a rolling harrow on the back for firming and smoothing. I am cheap so I took some used soil saver coulters and cut out my support discs with the plasma cutter and now I want to weld them to the axle. Question is how do I keep the shaft from warping. If I weld one side -say 1/4 of the way around and then went to the other side-180 degrees- and weld 1/4 of the way around and then let them cool and come back and finish welding would that help. It seems like everything I weld no matter how much I clamp it warps a little. The pictures of the completed baskets are a store bought ones. This is tractor related for we are going to pull it with a Deere!-Thanks---Tee
