OK, I put a loader back on my tractor. The pump runs off the front of the crank via a flex shaft to a hyd pump that has a base-plate mounted to a plate steel loader frame. To clarify, the base of the pump housing is parallel to the driveshaft.
All the repl pumps I'm seeing are over $500. However, those concentric plate pumps, where the shaft comes right out the mounting plate are only $149 at Northern Tool.
Does anyone know of a decent pedestal mount pump that isn't so costly?
Example:
https://www.amazon.com/BSM-Pump-117-713-20-8-Pedestal-Mount/dp/B004GZG05O
Example:
