B john deere crank
Ronjacobs
New User
I just purchased this b john deere and the pto side of the cranks where the splines are were welded up previously any way to fix them the balance is sloppy and chirps when it runs, any help much appreciated
Are you talking about where the flywheel is located or the PTO out the back of the tractor? If it is the flywheel, is welded to the crankshaft?
Seen many welded up. The late A's were the worst. The clutch hub would be all loose. As others said a used crank is not to far away!!!
