jared in wi
My father is working on a starting issue on a tractor for some one. The owner of the tractor had the starter off and repaired and the batteries removed and tested. Batteries tested good... I have had this happen to me as well. Where I suspect that I have a battery issue, I take the batteries off and have them tested only to have them test good at the store, they still do not work when installed in the machine. Also, when they are tested, I have noticed that the store personnel charge the batteries up first and then perform the test right after the charger is removed. This is when the battery tests good. However when I replace the battery or batteries, the issue goes a way. has any one else ran in to this issue??
Jared
Jared
