Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Can I save this tire?
sms
01-03-2018 12:27:23
Just took it off the front of a running tractor. Yes, it was holding air. I can't read the date code. Do you think WWII or Korean Conflict?
RN
01-04-2018 12:22:09
 Re: Can I save this tire? in reply to sms, 01-03-2018 12:27:23
Not a recommended by DOT for road use method-- but has been used for farm/offroad/parade use work-- find friendly Harley dealer with near bald center 5:10x16 tire from dresser and use it and tube as inner liner for the really bad looking but right outside size 16 inch tire needed for implement or old vehicle not used on interstate system. Some 15 inch rear tires for couple motorcycles available at times, skinny 4:25x16 for the small/midsize also around and taken off tire with good case, worn center tread is price of can beer- disposal cost for small tires about same as larger tire for tire dealers. Slime and foam padding in center of rim to take up some space works good enough for most utility work, extra slime helps in some scrap yard work if you don't want the $100.00 foam filling. 7:00x16 old Jeep tire can use the 5x16 or newer 5:10, 5:25x16 as inner liner- might need to sand off the nearer outside edge good tread, might just squeeze in with minimal problem. some ag tire dealer will have specific liner kits that will do same basic thing for extra money- might be about only option for bigger rear tractor tires but the smaller front wheels with 15, 16 inch tires can be quick , cheap fix if you have access to the used motorcycle tires. Ford N 19 inch fronts with nasty side wall cuts- many motorcycles used a skinny 19 inch front wheel/tire that tucks in easy enough. Brother 'borrowed' one of my salvage shelf motorcycle tires for quick repair of neighbors tractor tire and they were still being used about 3 years later, 3 or 4 repair jobs using my emergency use takeoffs, patched tubes that were in old shed. Either that or check Miller Tire for new tire - cost may be OK for you but most users of YTMAG seem to be 'thrifty' (cheap, tightwad, miser, poor, closed purse, squeeze a nickel till it screams :>). RN
Copperhead don't play
01-04-2018 06:41:27
Why not rattle can spray paint it and list it as restored?
Kirk-NJ
01-04-2018 04:13:58
I guess it depends on what your using it for. What ply is it? This one is still on a parts tractor. Just air it up if I need to move it.
Richard from SE AZ
01-03-2018 20:58:24
Sure. Take it off the rim and put it in a safe place in your shop. You can save it for as long as you want.
Stephen Newell
01-03-2018 18:54:53
Gees, I thought I had old tires. I'm still driving on tires on my jeep I bought in 1998.
carvel minne farmer
01-03-2018 18:25:52
I think you should trade it in before you loose any more money on it :wink:
big tee
01-03-2018 16:46:01
Yes you can save that tire-I would save it until I had a brush pile to burn and put it under it with 5 gallon of waste oil and a Ohio blue tip.---Tee
Brendon Warren
01-03-2018 16:28:36
16 inch? I've got a few of them kicking around. Brett 4207 got a couple for fronts from me. To bad you weren't closer. I'd hook you up.
sms
01-04-2018 03:45:17
 Re: Can I save this tire? in reply to Brendon Warren, 01-03-2018 16:28:36
Working on my MM RTI with Lull loader. Originally had 5 rib implement tires on the front, I have two from a parts tractor but they are getting rough too. Will probably buy new 5 rib once the tractor is all fixed up and put to work.
oldiron29
01-03-2018 15:29:03
I had a 40" knobby in the same shape as yours on a Farmall F-12 Guy told me they fill them with foam solid. don't know how it would ride or hold up over time.
37chief
01-03-2018 15:25:28
There may still be some warranty time left, better find the date code. Stan
Adirondack case guy
01-03-2018 15:09:08
A little paintable calk, power sander and some black spray paint and it will look great until you put it back on your MM, I presume, and use it.
That wasn't much help was it!!!! Just a way to spend a frigid day in your heated shop this weekend. HeHe.
Loren
Ozlander
01-03-2018 14:08:05
If it was holding air, Why did you take it off?
glennster
01-03-2018 13:57:15
id put a liner in it, a new tube and half a gallon of slime and run er fer another 20 years!!!!
Loren in Iowa
01-03-2018 13:55:20
Looks like it went through both wars.
steve706
01-03-2018 13:54:20
Looks like a typical non directional tire used from ww2 until the late 70’s, hard to pinpoint without code. Firestone still makes them.
CH(Upstate,NY)
01-03-2018 13:38:42
Duct tape?
SVcummins
01-03-2018 13:28:52
I’ve used worse but i wouldn’t air it up to standing next to it
Andy Martin
01-03-2018 13:06:44
If it was holding air I'd still be using it.
I have one worse than that on a grain drill. It's always flat when I go to use it but it will stay up a couple of days so I can plant and park it. Every year I think it won't air up but it always does, after sitting flat all year.
Janicholson
01-03-2018 13:05:08
That Goodyear had more than one in it. It cracks me up. Jim
TBA
01-03-2018 13:04:07
No
Luck ran out
Steve@Advance
01-03-2018 13:04:06
Yes, it would make a nice raised flower bed.
dahlin
01-03-2018 12:39:14
yes put in a box and put it on the self and look in on it occasionally.
9001ron
01-03-2018 12:36:12
Is that 16inch -- it likely to be so stiff you will need to cut it off. If that is the same as the tiers I have they are flat most of the time and you cannot tell-- very thick and hard.
Mike M
01-03-2018 12:32:22
Be lucky to get a few years out of a new replacement ! They don't make them like they used to.
