Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Pump house
JimS
01-03-2018 12:03:41
Our pump house burned in the Nuns Fire here in Sonoma County. I need to construct a new one. For obvious reason, I am rather turned off by wood construction (the old building construction). It is a small building, 6x6 on an existing concrete slab. I would like to construct it out of metal and I would like to have at least one wall and the roof easily removable to be able to service the well without destroying the structure. What type of construction would you employ and how would you build it. It needs to be reasonably economical. We seldom have weather below 30 degrees F. 20 is the coldest I've seen here. Thank you.
showcrop
01-03-2018 16:34:58
 Re: Pump house in reply to JimS, 01-03-2018 12:03:41
Does this building house just a pump? Or does it also cover the well? What type of well? dug or drilled? what type of pump? jet or submersible? Does it also house a bladder tank? How big?
showcrop
01-03-2018 16:25:41
Janicholson
01-03-2018 13:10:56
Buy a concrete manhole Set it on the foundation and put a manhole cover on the top. Jim
Adirondack case guy
01-03-2018 15:13:46
 Re: Pump house in reply to Janicholson, 01-03-2018 13:10:56
Janicholson---Perfect solution. Fast cheap and easy.
Steve@Advance
01-03-2018 13:01:31
Are there any metal building suppliers near you?
Most are customer friendly, will work with you on design.
They have worked out the most economical system of construction, yet provide a durable product.
There are Youtube videos of metal building construction. If you familiarize yourself with the concepts, look at available components online, then go to the showroom, ask questions, get quotes.
They can provide weld up, or bolt together framework. Sounds like you would want bolt together for ease of access.
kevinj54
01-03-2018 12:48:10
Pre cast concrete should work
Mike M
01-03-2018 12:34:39
Home depot lowes etc. sell metal studs and pole building siding/roofing. You could use that and screw it all together. It would come apart easy.
old
01-03-2018 12:17:27
If it where me I would do it with rock and concrete that way a fire is a whole lot less likely to take it away again. While metal will not burn it will melt and In a fire I have seen metal building fall faster then a wood building does and well a rock on will stand even in a fire
