TractorLinks.com
Tractor Talk Discussion Forum
Practical Modern Use for HitNMiss engine
allenlane
01-03-2018 11:58:18
Not exactly a tractor, but a close cousin. I'm trying to justify adding another project to an already longer than a lifetime list of projects. For some reason, these darn engines have always drawn my attention, but I can't get one just to take up room in an already crowded shop. Do you guys have any good modern uses for one of these (we don't have a farm, just horses and dogs).
Rodney51Cub
01-05-2018 18:42:31
 Re: Practical Modern Use for HitNMiss engine in reply to allenlane, 01-03-2018 11:58:18
Here is one from a local show in 2015. I know nothing about it. Just liked the ingenuity.
Rodney 8)
allenlane
01-05-2018 14:55:19
Jon, can you describe the drivetrain for us?
David Snipes
01-05-2018 13:58:38
I saw one powering a home made aluminum can crusher. The cans were stacked in some kind of tall tower; as the engine ran, it would push a can out of the tower and a weight which the motor raised, fell down crushing the can. The system then repeated itself.
Wheat47
01-03-2018 20:16:30
A member of our tractor club has a small hit and miss hooked to an ice cream maker.
But he's so busy at the show, he can make only 3-4 batches a day, and just pass out samples.
I have seen pic's of two ice cream makers on one engine.
Also saw a water pump on an engine that fed a water fountain. He added some VERY sudsy soap and some blue or red food coloring and had soap suds all over.
The kids had a great time playing in the "foam".
The overhead line shaft that powers the trip hammer, band saw, hack saw, and drill press in our blacksmith shop is powered by a 10 or so horse hit and miss. Works great.
Now, if we could find something for our 50 horse hit and miss to power!!
I suggested a big pump and fountain in the irrigation ditch!!!
Jon Hagen
01-03-2018 19:41:59
This is throttle governed(IH model ??) instead of hit & miss, but still interesting, A motor cycle built from farm parts
Paul Janke
01-03-2018 18:28:00
Using it to run a buzz saw might be an idea. I once saw one being used to run a concrete mixer. It might also be a good power source for a wood splitter. Maybe running an air compressor for winterizing sprinkler systems.
VADAVE
01-03-2018 15:25:35
I was going to say generator then realized you need a steady rpm. Try a compressor air up the tank set it to kick in and keep it aired up. Water pump. You some of the old uses are still good today.
patsdeere
01-03-2018 15:11:06
Hook one to an ice cream maker. Perfect modern use. Takes about 15-20 minutes and you have perfect ice cream and a usable arm to eat it with.
CCer
01-03-2018 15:04:32
When my Wife walks by a running Hit n Miss engine, she always asks "Is that all it does?"
da.bees
01-03-2018 14:30:34
Two things that currently use a lot of hit and miss engines is fishing/shrimp boats and remote oil wells. Personally I would like something for parades and tractor shows.
Dan in North Houston
01-03-2018 14:04:00
I always thought that the hit and miss engines powering an old fashioned ice cream maker was all the justification needed to get one.
allenlane
01-03-2018 13:41:08
Excellent ideas fellas. Keep 'em coming. Thanks John and Ken for posting those pics. Johns project looks ambitious and a little over my pay grade, however I think I could handle the go kart.
Ken Christopherson
01-03-2018 13:12:29
I have always wanted to fit one into a vintage riding mower to use as a show putter.... Guy named Jack at my local show here (Nowthen, MN) has a go-kart he made with one. It's his tool grabber. Uses it to run around at shows when one of his many large kero or gas tractors needs a little help. Actually a pretty cool little thing!
Jon Hagen
01-03-2018 12:41:32
My hit & miss powered trike. Great fun and conversation at parades and antique shows.
SweetFeet
01-03-2018 13:47:51
 Re: Practical Modern Use for HitNMiss engine in reply to Jon Hagen, 01-03-2018 12:41:32
Jon Hagen,
I give a big thumbs-up to the trike AND the cap. :)
Jon Hagen
01-03-2018 19:52:34
 Re: Practical Modern Use for HitNMiss engine in reply to SweetFeet, 01-03-2018 13:47:51
Thanks Sweetfeet. By my hat you can tell I like the Armorall mascot and the Hager The Horrible comic strip.
Below is a video of my Hit& Miss trike running
sms
01-03-2018 12:22:20
I have flat belt machines and some lineshafts, always wanted to set up a building say 8x20 on skids with a few machines powered with a hit and miss. Then I could winch it on the trailer and take it to shows and use the machines any time if I needed to.
9001ron
01-03-2018 12:20:23
I am an avid collector my self .You need to specify what kind of stationary engine you have exactly . In reality a practical use for your motor could range from a awkward boat anchor to a sizable future wise investment on your part . You need to redo this post on smokestack .com -- that is where the fanatical collectors hang out . Most of what you will get here is a bunch of cowboys that cant fix there tractors right HA HA HA!
The best use I found for one of my motors was to prevent a break in to my garage . the motor was a 6 hp grey and it weighs 1300 lbs . I had it positioned with one of the flywheels up against the side wall of my garage . The Bandits used a screw driver to pry out the 3/8 plywood exterior wall and then pulled out the insulation from the wall. They found an interior wall of 1/2 osb and decided to try to kick it in with there feet . Needless to say they found it impossible to do and gave up . I could see all the foot prints on the vapor barrier . So if you see a bandit carrying a big screw driver and walking with a limp let me know .
old
01-03-2018 12:14:37
You could rig it up to say power your shop or house if the power goes out and set it up to pump water for the garden etc. I've always wanted an old steam tractor so I could set it up to make power and maybe saw my self some $$ or even make some $$ by selling the power to the power company
Dieseltech
01-03-2018 12:06:34
My gas hopper cooled engines are in charge of heating hot dogs and boiling eggs when running at shows, otherwise they just make noise..
