Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Talk Discussion Forum
Re: How much traction do you gain with chains?
BarnyardEngineering
01-03-2018 10:28:42
Your biggest problem is the useless "pull-type" snowblower.
Those are only good if you don't get more than a few inches of fluff. Otherwise you are struggling through big snow drifts, beaching the tractor, trying to pull this thing through.
All chains will do is ensure you get even more stuck, quicker. The problem is clearance under the belly of the tractor. You can only go through snow so deep before the tractor gets high-centered on the snow. Once the belly of the tractor is sitting on enough snow the wheels can't touch the ground, can't get any traction, and you're STUCK, whether you have chains or not.
Effective snow removal in any appreciable snowfall requires the tractor to be BEHIND the snow removal implement, on cleared ground.
denny k
01-03-2018 11:51:58
 Re: How much traction do you gain with chains? in reply to BarnyardEngineering, 01-03-2018 10:28:42
Hey Barnyard Engineering, How did you get a picture of my 8n and Erskine snow blower? 8-) I have had mine since about 1972 and it was built in about 1948 or so. My dad bought a new one in 1950 and my serial # is lower. I have blown more snow than I can imagine after living in Minnesota and now South Dakota. If you know its capabilities and limits it will work for many, many years with little or no maintenance except greasing. In the 30+ years my dad had his he only replaced the pillow block bearing housing once, bearing was fine. On mine, I removed the fan several years ago to straighten the fins and then balanced it so it spins beautifully.
