showcrop
Common Tractor misconceptions, what can you add?
My wiring connections are clean, and the battery is new so it has to be a bad starter.
Starters and generators were always painted black from the factory.
Water could only have gotten into my transmission or hydraulic housing through some hole in the top that they left in it at the factory.
I need to convert my NFE tractor to wide front before I can use it to brush hog my back yard, or it will tip over and kill me.
The spark is weak so I need a new coil.
