RE Marvel Schebler carb
JK2
In reference to the fellow looking for MS carb gaskets a couple pages below.
Tisco sells gasket kits for these carbs for less than $5.00 in sizes that fit any MS carb that I have encountered. Some of the kit numbers are below:
CGK32
CGK33 - Oliver 1600-1800
CGK38 - MM 5*, M5, M602, M670
CGK40 - use with kit BK370V
CGK43 - use with kit BK373 (TSX-810)
CGK44 - MM 4*, Jet*, Jet*2, Jet*3, Big MO
I have seen some of these kits at TSC & local dealer keeps some of them in stock & will order others.
I have scanned copies of a few gaskets and printed them off on gasket paper. It took a few tries on regular paper to get the size right because somehow something alters that in the process, but when you get it right,,,,,, wah-la (Walla?) (Wall ah?) anyhoo,,,,,,, gm
Did that for mine, too, before I discovered how easy it was to get new ones. M-S carbs came in two sizes, small bowl and large, kits are readily aveilable for either. Get a new float while you're there.
