pat sublett
What would you use on a tractor conversion from Generator to alternator, 1 wire GM or 3 wire?
our rebuilder is correct. I prefer the configuration with an idiot light on the dash, gives you a heads-up if the belt snaps so you can shut it down before you cook the motor. Even if you forget to look at the temp gauge.(quoted from post at 18:36:36 12/09/17) My rebuilder suggests 3 wire. Says they can be built to start charging at a lower RPM.
So that is what I use.
