Trouble shooting a governor
Well I thought I had it adjusted, but everyone kept telling me it was the carb that was giving me trouble. I was given a cut away of the carb and took it apart again soaked it over night, while putting it back together I discovered that the idle jet was plugged solid, after receiving the cutaway I can say for a fact that all passageways are open. Now to put it back on and see what happens.
If I thought it would help I would, cleaned the carb and put it
back on and nothing has changed I can still screw the idle
adjustment screw all the way in and nothing has changed.
Glad I am not the only wiseguy on here. First thing that came into my mind was..."you just got to catch him out in the open!"
(quoted from post at 13:15:24 11/16/17) If I thought it would help I would, cleaned the carb and put it
You missed some crud somewhere.
(quoted from post at 13:11:45 11/16/17)
your title says.. you are having trouble,,, shooting a governor...
that might be against the law... ;)
Might want to be aware of the possible ricochet.
We tried shooting our last gubner, but he got beat by a Repuglican last election. Then, tha dumazz ran fer Presydint, an coulden even get mor then a fistfull of votes in this state......
hey Tex.........iff'n yer carbie is a M/S, yer idlemix screw is BASS-ACKWARDS; OUT fer LEAN, IN fer ENRICH. Always adjust yer carbie fer FASTEST idle, NOT SMOOTHEST idle. Understand the DIFFERENCE??? Shuld be about 1/8-1/4 turn .......Dell
