My loader on the 1635 would not produce down pressure, but otherwise worked fine. Took it to the dealer and they replaced the quick coupler for the down pressure side of the loader arm cylinders. Seems when the oil flow thru the coupler was at low pressure (arms dropping due to gravity) it would flow fine. But as soon as the bucket touched the ground and pressure increased, the ball would snap shut putting the system into bypass and no flow to the cylinders. No leaks, all internal failure. Mechanic says he sees that happen often, even OEM fittings are sometimes cheaply made. I'd never seen a coupler fail like that before but sure glad it was something simple. Pays to check the simple and cheap stuff first I guess.
