TheFarmallMan82
Hey all! Thanks so much for helping me out with my Stuck clutch on my 1928 Regular, you were all a big help and I did get it off. Now I am having a problem trying to get the flywheel off. Its the old style flywheel where it has the 3 prongs where the clutch went and has 3 holes near the center. I have a replacement I need to put in as well as a newer style clutch and I really need to clean behind it because it is so stuck that it will not move at all. I pulled about 10lbs of mouse crap from the housing and I've tried to use a 3 prong puller but had no luck. I don't have a welder so I cannot make a puller myself, Otherwise I would. I would like to have a puller where I can use my 12 ton hydro jack but unfortunately as far as I can tell, no one around makes them or sells them. Any input will as always be appreciated!! Thanks guys!
