Pulling disc with JD 401
37chief
Location
California
I hooked up my 8 ft disc to my JD 401 Industrial, just to see what it would do. It has the power, but even with large tires all it did was dig in. The ground was fairly soft. I don't have filled tires, because I don't need it for mowing. Does filled tires make that much difference? Stan
Does it have industrial tires with wide lugs to float over soft ground or does it have ag tires with narrow lugs to penetrate and grip soft ground? Ballast will help, but ag (R-1 ?) tires will help more. If your industrial tractor has a loader, that will pull some weight off the rear axle.
