Brake fluid
37chief
Location
California
I needed new brake fluid for my brake job. I purchased dot four, because it said it was rated for a higher temperature. I thought that would be good. I went to fill the master cylinder, the cap said use only dot 3. Will dot 4 work or should I go and buy dot 3? Any thoughts. Stan
Just don't use DOT 5. DOT 3,4 and 5.1 are all glycol based. DOT 5 is silicone based and is just plain bad news. Also don't use LHM fluid, which is typically used on some european stuff, as well as some euro built CNH tractors.
