New Idea picker question
G.Fields
Im getting my new to me picker ready to go, and was getting the vines, and corn stalks that were wrapped around various shafts cut off. I noticed that the idler sprockets on the gathering chains were loose, and one was tight. i took a couple of them apart, and to my surprise there is no bearing. Just a male, and female cone(for lack of the correct term). I checked my manual, im not missing any parts, and the lubrication guide makes no mention of lubricating them. I dont think grease would be the answer, it would collect dirt and dust. It seems it needs something? Maybe dry graphite? What do you guys think?
Been years but when we did it was plain old kerosine, no diesel as that has too much oil in it to gum things up.
They run for years that way. I try to get some oil up in there when I oil the chains, but don't know if it gets there or if it does any good. I believe they are cast iron and that may wear better.
I've had three of those pickers, I use a 323 now through about 10 acers a year. They were all as you describe with no bearing or grease zerk. Just the way they are and I never had any problem with them. I just dump used motor oil on the chains now and then and when I put it away for the year.
